Hi, Team
Hope you are doing well!
My customer has some questions when they use our TCAN1044-Q1.
1) What is the power strategy of TCAN1044-Q1 under sleep? If it is necessary to be able to wake up via the bus, then in terms of power supply, is it required that Vio has power and VCC can be powered off? Or does it require Vcc to be powered, and Vio can be powered off?
2) Regardless of whether VCC or Vio is required to be powered, in order to reduce the quiescent current, is it necessary for STB to be active in Standby mode?
Thanks & Best Regards
Jeff
