Part Number: DP83TC814R-Q1
Hello expert,
My customer is designing circuit using DP83TC814R-Q1.
Then, we have question regarding RX/TX pin under RMII mode.
For this pin, there isn't internal pull resistor under RMII mode operation.
Then, they'd like to place pull down resistor to avoid unstable condition.
First could we place PD resistor on RX/TX bus?
Second, if they can place PD resistor on RX bus, would you tell me recommended selection method of PD?
This is because, this pin work as pin strap at start-up so they also consider this value.
So they'd like to know about how to balance this point.
I'm looking forward to hearing back from you.
Thank you and best regards,
Kazuki Kuramochi
