DS90UB928Q-Q1: Unused pins configuration
Part Number: DS90UB928Q-Q1
Hello TI,
Currently I'm using DS90UB928Q-Q1in my design .Not using below pins , should i keep them  in floating state or pull down using a resistor ?
And also what is the configuration need to followed for  other unused pins in the IC. Please help me
Thank you
  • Hi Ramana,
    If the pin is described to have an internal pulldown which is enabled, then you can leave it floating. Otherwise, an external pulldown resistor is recommended.
    In this case, these pins should have internal pulldowns, but if you still want to use an external pulldown, that should be fine as well.
    Ryan
