Part Number: TCA9617A
Other Parts Discussed in Thread: TCA9803
Hi Team,
my customer is using TCA9617A as the I2C level shifter.
But we met one issue: There is big noise on B side from the slave side, and during the A -> B transition(I2C write), the B side Vol(~0.55V) will be dropped to be below than 0.45V due to the noise, which cause the TCA9617A does the B -> A transition, but actually it is A -> B transition.
This wrong direction transition causes the I2C bus stuck, 2 clks missed on the level shifter A side (master side).
So, here I have below questions:
- Please check if we have other level shifter parts that have higher B-side Vol voltage.
- Please check if Twe have the similar issue on TCA9617A and how we fix the issue.
thanks very much!
