Part Number: TCAN330
Other Parts Discussed in Thread: SN65HVD232, TCAN332
The customer has a demand for a CAN bus transceiver, which requires CAN signal input and RS signal output. Whether SN65HVD232 is the best solution?
Charlie
Charlie
Hi Charlie,
The newest standard CAN transceiver that I would recommend for a basic CAN application would be the TCAN1044A. This is a 5V supplied, 8-pin CAN transceiver that is capable of driving and receiving CAN FD frames up to 8Mbps (or down to 9.2kbps). If this application does not have a 5V supply rail, a similar 3.3V supplied CAN transceiver would be the TCAN332 which can handle up to 5Mbps.
Let me know if you have any questions on these devices or the CAN standard in general.
Eric Schott
