DP83826E: Typical application guide with Strap configurations at RMII Master Basic mode
Part Number: DP83826E
Hi Experts,
Seeking your guidance on this query I am posting on behalf of my customer.
Initially, they are asking the reference design for DP83826ERHBR, as they wanted to know how to design STRAPS pins for RMII Master Basic mode, with the LED0/1 pins. Referred them to its EVM references.
Now, they would also like to know all Straps configuration externally with resistors.
For example, in the Table 7-1 of the datasheet of the DP83826ERHBR stands for the strap4 (pin name COL) that the strap is not used in RMII mode, but in section 9.4.1.2 in the strap configuration for Basic mode we need to pull the pin up to high for RMII master mode.
For strap1, according to table 9.4.1.2 as well a pull up to high for Speed 100M is needed but with your description its pulled down go GND.
Could you give me some advise about the other Straps at RMII Master Basic mode?
Archie A.
www.ti.com/.../snla338a.pdf
