Other Parts Discussed in Thread: THVD2450
Hi team,
Does TI have a P2P solution with LTC28621? if so, Could you share compare table for me? thx
Hi team,
Hi Jimmy,
Our best part would be the THVD2450 as Clemens mentioned.
Some quick highlights:
| Parameter | THVD2450 | LTC28621 | Comment |
| VCC | 3V to 5.5V | 3V to 5.5V | |
| Common Mode Range | +/-25V | +/-25V | |
Fault Protection Range |
+/-70V | +/-60V | |
Duplex |
Half | Half | |
Max Data Rate |
50Mbps | 20Mbps | |
# of nodes supported |
256 | 256 |
They are available in same packages with same pinouts. The biggest difference is that TI's device has a higher protection rating and can't achieve the same maximum data rate which the comp device can.
Parker Dodson
Hi Jimmy,
Glad I was able to help please let me know if you have any other questions!
Parker Dodson
