Part Number: TLIN1028-Q1
Hi Expert,
I would like to check with you what is the behavior for TLIN1028-Q1 when VCC output current reach the current limit threshold?
From the datasheet, my understanding is that when there is overcurrent situation happens on the VCC. The internal LDO will limit the output current to current limit value(275mA). And the output voltage will drop. If the output drop below the UVCC level, nRST will be pulled low. But the internal LDO will not be disabled. The LDO will keep output until thermal shutdown. Is it correct?
Thanks!
Ethan Wen
