Part Number: TCAN1145-Q1
Hi team,
Is there any side effect if I set SW_EN = 1 and stay either Standby, Listen, Normal state?
regards,
Hi team,
regards,
Hi Tsuji-san,
When partial networking is enabled (SW_EN = 1) in any mode, the transceiver will begin to monitor the CAN bus for a WUF. The main undesired impact of this is if a frame overflow would occur during this time and set the FRAME_OVF flag. If this flag is not cleared before entering Sleep mode, the partial networking function will not work correctly. Therefore in order to avoid this, I recommend only setting SW_EN at the same time as the transceiver is being put into Sleep mode (both done in the same write to the mode control register).
Let me know if you have any more questions.
Eric Schott
