Part Number: TS3USB221
Hi
1.Does TS3USB221 have timing requirement for S/OE?
2. If the OE=H, in disconnect mode is the 1D/2D/D are floating?
Hi Far,
Thank you for your questions.
Are you asking about Is the question referring to propagation delay? If so, tpd is 25 ns typically. See section 6.8 and 6.9 for line enable/disable times.
Switch is disabled in this mode and D+, D- signal will not be communicated to 1D or 2D.
Stanton
