Part Number: SN65HVS881
Hi Folks,
According to the datasheet: https://www.ti.com/lit/ds/symlink/sn65hvs881.pdf?HQS=dis-mous-null-mousermode-dsf-pf-null-wwe&ts=1679662106302&ref_url=https%253A%252F%252Fhu.mouser.com%252F
Please consider the Figure 13. and Figure 23.
sorry, that I don't have schematic, I try explain my intention by this way:
- The reference design states that in "normal case" the switch that I want to sense, should be connected between my VCC and IPx, while REx should connect to GND via LED.
- In my project I'm going to sense switches connected between GND and my device input, so I will provide a screw terminal where that user can connect his switch between GND and the input.
So the question is: is it possible to lead out the LED's cathode as my "input" to the terminal and powering the IPx input via VCC. And by this way, I expect my customer, to install a switch towards GND?
Thank you
