Part Number: DS125DF111
Hi Expert,
What is the difference between retimer and redriver? Thanks
David
Hi Expert,
David
Hi David,
Redrivers use equalization and gain adjustment to compensate for insertion loss and re-transmit an equalized signal.
Retimers use the same techniques to equalize an attenuated signal, while also using a CDR circuit to filter jitter out of the same signal.
Redrivers and retimers can both compensate for insertion loss, while only retimers are designed to compensate for random jitter.
Thank you,
Evan
Hi Evan,
Thanks for your feedback. So Redriver is the subset of retimer?
David
Hi David,
Yes, in terms of them both sharing equalization functionality.
Evan
