Part Number: DS125DF111
What is the placement requirement for In/Out pins AC caps
Hi Kanava,
We recommend placing the AC caps as close as possible to the IC. Please refer to section 10.2 in the datasheet for an example.
Evan
For both Input and Output pins? I think AC caps for output pins should be placed closer to the Receiver IC.
In 8.2.1 "place AC-Coupling capacitors for the transmitter links near the receiver for that channel"
Sorry for the confusion, my previous response only applies to the input pins of the receiver IC. Following 8.2.1, place all AC caps as close as possible to each receiver end of the signal chain.
Thank you,
Evan
