Other Parts Discussed in Thread: ONET4201PA
Here are the questions for the ONET4201PA;
- what is the propagation delay through the amp (I could not locate this in the datasheet).
- they would also like to use this as single-ended input, AC coupled. Will this be a problem?
- they will use this at 100MHz, which is below the 155MHz minimum, an issue?
-Tom-
