Part Number: ONET4201LD
Other Parts Discussed in Thread: ONET4291VA
Hello there,
we use laser driver ONET4201LD to drive laser diode (LD) with monitoring photodiode (MPD) - connection type A in TO56 chassis. However this connection does not allow us to place the LD chassis into conductive housing with GND potential. Resulting short circuit of VCC on LD chassis and housing with GND.
What LD configuration we should use with ONET4201LD to have GND potential on the LD housing (common pin 2 connected to LD chassis) and still be able to use MPD?
Can the ONET4201LD still drive other LD types? Could you please draw recommended circuit with GND on LD chassis, MPD and ONE4201LD?
Thank you a lot,
Michael
