Part Number: DP83826E
I would like to use the interrupt pin of this chip as a system wake up source when a WoL packet arrives.
The problem is that in order to communicate other event to the MAC, some other interrupt sources must be active and they also make the interrupt pin toggle. Is there any way to make the interrupt pin toggle only if a WoL packet arrives instead of every time an enabled interrupt occurs?
