Part Number: SN65HVD1050-Q1
Other Parts Discussed in Thread: TCAN1057A-Q1
Our customer is having problems with their nodes. When they hook up our device, it causes frame errors on their nodes because of our noisy PCB injecting the noise into the CAN bus.
If the noise is common mode, it should not cause any frame errors, am i correct?
Could it be that their transceiver is not good enough at rejecting the CM noise?
Could it be that the ground shift is too high? We have isolated systems so the ground does shift.
Why do oscilloscopes use only H or L for decoding and triggering CAN errors when the actual use case is using the differential signal? We are using Kvaser to communicate to our PC and we get 0 CAN errors, so how come our customer is having issues on their nodes?
Please let me know what other information i should provide, if that helps.
Thank you,
Valentinas
