FPC402: Can FPC402 set baud rate? what is the time gap limitation between each I2C frame?
Part Number: FPC402
Hello expert,
As title, when CPU try to access FPC402 via I2C, could FPC402 define I2C baud rate ?
Or what is the time gap limitation between each I2C frame ?
Ann Lien
  • Hi Ann,
    Minimum time gap you are referring is called bus free time or time between STOP and START condition of I2C interface.
    Please note FPC402 parametric table. On the host side this is called tBUF and it is 0.5uS minimum. On the other hand, on the port side, this is called tBUF again and it is 20uS(minimum).
    Regards,Nasser
