Part Number: AM26LS32A
Other Parts Discussed in Thread: AM26LV32
Please let us know the maximum supported data rate (Mbps) of AM26LS32AIDR chipset.
Arun Gomathi R
Hardware Design Engineer
DATA PATTERNS INDIA LTD
Chennai.
The datasheet specifies a worst-case propagation delay of 35 ns. So the maximum data rate is at least 28 Mbps.
The website says the maximum is 10 Mbps. This is obviously wrong; the actual maximum is likely to be the same as for the AM26LV32(E), i.e., 32 Mbps.
Hi Arun,
The max data rate is generally limited by the drivers' transition time (typ. 1/3 of rise/ fall time) and not so much from the receiver side. As Clemens' mentioned, this device is capable of meeting the spec of the driver (hence 32Mbps).
Jack
