Part Number: TUSB7340
Hi team,
Could you please comment on the pin delay of this device? Thanks!
Nison
Hi team,
Nison
Nison:
Can you explain more?
Regadrs
Brian
What is Pin Delay?
The distance between the core unit and the packaging pins inside the chip becomes Pin Delay. In high-speed circuit design, it is necessary to consider the Pin Delay of the chip to reduce wiring length errors.
Naizeng:
I can check , but all timing information of all control signals should be in datasheet. ANy particular pin custotmer are interested?
Regadrs
brain
