Part Number: TCA9548A-Q1
Other Parts Discussed in Thread: TCA9517-Q1
Team,
Customer plans to use TCA9548A-Q1 in their application, and they consider some worst case scenarios in termls of Controller MCU SDA/SCL load current.
Scenarios:
--> 1 output channel active in fast mode, 3.3V pullup
--> all 8 output channels active in fast mode, 3.3V pullup
There are two questons:
1. how to calculate pull resistors on controller and output channels sides, to makes sure both cases work correctly? (I tried to use I2C designer tool, but I cant find TCA9548 there..)
2. TCA9548A-Q1 datasheet say:
What does it mean to the MCU Controller SDA/SCL pins current capability?
Can you help to calculate currents that MCU Controller needs to support?
What if this current is outside of MCU Controller capabilities... can you recomend any I2C automotive buffer IC to help?
