Part Number: SN65DSI83
Dear Team,
I am using SN65DSI83ZXH in one of my project. Below is the schematic. If you don't mind could you please check it
HARI
Hello, Hari,
What's the application that you are working on?
I recommend change you ADDR pull up to match the PU resistors on the SDA/SCL lines.
Please ensure that your enable signal timing will be able to meet t_en in the datasheet. Refer to section 7.4.1 in the datasheet.
Zach
Hari,
Good starting place to tune if needed for the enable pin.
Zach
Hari,
Per the Hardware implementation guide, that is correct. The hardware implementation guide uses a 4.7k ohm as an example. You just need a Pull down resistor to GND if not in use.
Zach
