DP83848I: Can DP83848I used in the Audio transmission scenario with AES67 standard
Part Number: DP83848I
Hi team
My customer CVT wants to use our PHY device DP83848I in their commercial display project. The device is to support the microphone signal transmission with AES67 standard.
To ensure the audio quality, the PHY CLK_OUT Pin must has the same frequency and phase as the received signal, that means the PHY CLK_OUT should be recovered from the received signal not just the copy of crystal oscillator.
Can DP83848I support this function? Or we can promote other device with can fulfill the function to customer.
Thank you!
May 15
Joe
