Part Number: DS90UB638-Q1
Hi Team
Could the FIT Rate and Failure Mode Distribution be provided for DS90UB638-Q1, which is used to evaluate the Failure Rate for functional safety to be compliant with ISO26262.
Best Regards.
Xianti
Hi Team
Best Regards.
Xianti
Hi Xianti,
You can find the FIT rate on the TI quality site below:
We do not have a Failure Mode Distribution available for the 638.
Cindy
Hi Cindy
What is the difference between this FIT rate on TI quality site and the FIT rate in the <FIT Rate and Failure Mode Distribution> document?
Because i found the FIT rate on TI quality site is 1.3 FIT for DS90UB948, meanwhile the FIT rate in <FIT Rate and Failure Mode Distribution> document is 53 FIT.
Thanks & Regards.
Xianti
Hi Xianti,
The TI.com website uses the JESD85 methodology to calculate the FIT rate. There are several standards used to calculate FIT, so if you are looking for a different FIT standard for the 638 let me know and we may be able to provide it for you.
Cindy
Hi Cindy
Are there FIT rate for DS90UB638 according to SN29500 or IEC62380 standard?
Thanks&Regards.
Xianti
Hi Xianti,
The FIT rates for DS90UB638 is the same as for DS90UB954.
Here is the FIT rate according to the IEC62380 standard:
Cindy
