Part Number: DS320PR810
Hi Team,
For the EQ selections below, is there a list showing the equivalent EQ boost (dB) at Gen3 speed of the DS320PR810?
Thanks!
Roy
Hi Team,
Thanks!
Roy
Hi Roy,
I've dug around a bit and found some approximate CTLE boosts at each EQ Index for DS320PR810. I've highlighted them in the table below. Note that values listed under each EQ are in dB.
| Frequency (GHz) | EQ=0 | EQ=1 | EQ=2 | EQ=3 | EQ=4 | EQ=5 | EQ=6 | EQ=7 | EQ=8 | EQ=9 | EQ=10 | EQ=11 | EQ=12 | EQ=13 | EQ=14 | EQ=15 | EQ=16 | EQ=17 | EQ=18 | EQ=19 |
| 4 | 1.0 | 1.6 | 2.3 | 3.3 | 5.0 | 3.3 | 3.7 | 4.0 | 4.5 | 4.9 | 5.5 | 5.8 | 6.4 | 7.1 | 7.2 | 7.6 | 8.0 | 8.5 | 8.9 | 9.3 |
As Nasser mentioned, you can use the S4P files for different EQ indices at Gen 3 as well (especially for simulation).
David
