Part Number: DP83TG720S-Q1
Other Parts Discussed in Thread: LM3880, TPS22993
Hi Team,
Can you suggest a power management module that would allow the user to enter/exit the sleep mode feature of the phy ethernet DP83TG720S-Q1?
Can you confirm the combination of a sequencer (LM3880) and a load switch (TPS22993) would work? if not can you suggest other devices? if possible a single IC solution?
Thank you kindly.
Marvin
