Part Number: ONET1151L
how to make ONET1151L work ?
im supply 1MHz to DIN+ DIN- i wonder if it is below the minimum ONET1151L device data rate
i wonder what should be the minimum signal in DIN- DIN+
Hassan
Hassan
Hi Hassan,
This is way below data rate supported by ONET1151L with a minimum of 1Gbps support.
Perhaps for 1MHz operation you may need to consider LED driver. Below is a link to TI LED drivers page:
https://www.ti.com/power-management/led-drivers/overview.html
Regards,Nasser
Hi Nasser
Thanks for the reply
The test conditions says different. can you explain to me these figures.
Can ONET1151L works at 100 MHz ?
Hi Hassan,
These are return loss measurements to show across signal bandwidth device response. Low frequency response is important since this shows DC response of the device due to the different data patterns with low data transitions. Also, please note statement below from the data sheet description below showing 1Gbps to 11.3Gbps. Device has been characterized in this data range :
Regards,Nasser
