TS3DV642-Q1: difference with industry grade
Part Number: TS3DV642-Q1
Other Parts Discussed in Thread: TS3DV642,
hi team,
i have two question about the device,
first what the difference of TS3DV642RUARQ1 with TS3D642A0RUAR. i see the datasheet TS3DV642-Q1 can support MIPI, but the datasheet of TS3DV642 not clear about support MIPI.
second about TS3DV642,  i would also like to ask how this HPD and CEC can be combined to form a differential  channel.
  • Most electrical characteristics are the same; both support the voltages and bandwidth for MIPI. The automotive device has a wider temperature range. Other differences are testing and qualification, which you do not need to care about if you do not need them.
    The electrical characteristics of all I/O channels are the same, so it does not matter which signal you send through which pin.
