Part Number: TLIN1441-Q1
Other Parts Discussed in Thread: TLIN1028-Q1, TLIN1431-Q1
Hi Expert,
I have some questions about wake up requirement in standby mode.
Firstly, in customer's use-case, there have some wake up detection requirements on MCU, so they need LDO on to supply MCU, but require lower power consumption in this case. So they can only use standby mode.
But customer requires that TLIN1441-Q1 is able to detect the wake-up request on LIN bus, then wake up MCU through RXD pin(high to low falling edge can wake up MCU).
From datasheet, TLIN1441-Q1's RXD is always low level in standby mode.
Can you confirm if my understanding is correct or not? If yes, it there any workarounds?
Thanks!
Ethan Wen
