Part Number: TLIN1028-Q1
Hi team,
When Vcc is not used, is a capacitor required?
Eric-san,
Thank you for reply. I understand. What is the recommended value for capacitor on unused VCC?
Hi Eric-san
I have additional question.
Could you provide Typ value of tpwr(Power-up time)?
Tabata-san,
1uF to 4.7uF will work for the output on VCC.
We don't have a typical value in our characterization data that I can find for tpwr. I'll talk to our design team, but why do you need this value?
Eric Hackett
Hi Eric-san,
Thank you for your reply.
I'll ask my customer why this value is needed and tell you later.
I'm sorry to ask you so many questions. Could you provide the state of pin in Unpowered system(Vsup < UVsup) like Table 9.1 of the datasheet?
Tabata-san,
I will have a reply for you by tomorrow, thanks for your patience.
Eric Hackett
Hi Eric-san,
The reason my customer needs typ value of tpwr is that they expect the sum of the every typ value when actually measure whole wake up time.
Tabata
Tabata-san,
Sorry for the delay here, I still haven't gotten a value for the typical value of tPWR, sorry for the delay on this.
If the system is unpowered, all pins will be high impedance, with their leakage values listed in the datasheet. Please let me know if you need to know more specific information.
Eric Hackett
Hi Eric-san,
Please let me know when you get the typical value of tPWR.
Thank you for your answer. I could understand that all pins will be high impedance in unpowered situation.
Tabata
Tabata-san,
I will update this thread when I receive more information about tPWR.
Eric Hackett
Tabata-san,
The tPWR value is not specified with a typical value due to its wide variance. Our test data has shown this varying, but always less than 2 ms. We have seen the power-on process finish as quickly as a few microseconds, but we have also seen it take longer than 1 millisecond. In general, it might be okay to estimate around 1 ms, but it depends on why they need it. Per above, you mention that they are using it for estimating whole wake-up time. If they want to do worst-case analysis for longest possible wake-up time, then they should use 2 ms. If they're just trying to get an idea of what it might be, then you could roughly estimate 1 ms with the understanding that it could be ±100% of this estimate across all corners.
Danny
Hi Danny-san,
Thank you for your detailed explanation. It is so helpful.
Tabata
