Part Number: DS280BR810
In the datasheet, it mentions the following...
8.3 Initialization Set Up
The DS280BR810 does not require any particular start-up or initialization sequence. The device defaults to a
medium boost value for each channel. It is recommend that the channels be appropriately configured before data
traffic is transmitted to the DS280BR810 to avoid issues with the link partner ASIC's adaption. Example
configuration settings can be found in the DS280BR810 Programming Guide.
Where can I find the DS280BR810 Programming Guide?
Also, Is there a way to put the DS280BR810 in a pass through mode where the signal is only minimally affected? I was looking to see the signal with and without (as best as can be achieved) the redriver.
Thank you,
Michael Nycz
