Part Number: DP83822H
We are using DP83822 Phy for IEEE1588 PTP in MII mode. In the data sheet mentioning only the RMII Master/slave operations.
Is there any strapping options needed for MII master/Slave operation for PTP.
Also when we are using Voltage translator ICs for the signals like PRXER, PRXDV etc, for the Strapping option to we need to Pull-up or Pull-down these signals. Then where have to place the resistor ? ( On Processor side or Phy IC side)
Sandeep
