DP83825I: 100Base-TX UTP+Vout Differential Output Volatge FAIL
Part Number: DP83825I
Hi Expert,
We are testing the 100Base-TX compliance test and two items failed as follows.
May I know which register setting can improve these two items? Thank you.
Another question, as Spec. mentioned the DP83825I supports 10Base-Te.
If Link Partner only supports 10Base-T, can DP83825I be fully interoperable with a 10BASE-T PHY?
