Part Number: TS3USB221A
Hi team,
During the actual application, it was found that the transfer rate could not be increased. The customer suspects that the actual capacitance value is higher than the value written on the datasheet. Is the typical value of this parameter item tested? What should they do if they want to get the actual capacitance value?
Could you help check this case? Thanks.
Cherry
