Part Number: DS160PR822
Hello team,
I have a question about DS160PR822 with I2C mode.
What EQ value will be set if user doesn't program CTLE value in I2C mode?
Hello team,
Hi Taketo,
It depends on the resistor control values.
Vicente
Hello Vicente-san,
Thank you for comment.
How about RX_DET default setting in I2C mode? In I2C mode RX_DET pin is uses as SCL and the pin has about 5kohm pull up, not pull down and not floating. What setting is read at power up as default RX_DET? Is it L3(floating)?
Greeting Sato-San,
It will be like floating - follows PCIe RX detection procedure.
Regards,Nasser
