Part Number: DP83826E
Dear TI,
I want to drive a high side LINK LED with pin30 (LED0/Strap2) pin of ETHPHY in enhanced mode directly. As far as I understood the data sheet PHY chip will detect the pull-up LED (~200 Ohm, green LED to +3V3) and will drive it with active low output. The same pin is a configuration input by the way, default 0.
I suppose the LED on supply side will be seen as strap to high. Am I right?
Best regards
Kalman
