Part Number: DS250DF810
I want use Hyperlyx Vx2.13 AMI simulation. It has issue. Please check attach file.
We are looking into this and will get back to you shortly.
Zach
Are you able to enable any more detailed logging in order to see which DLL is missing? Please note that we typically use Keysight ADS to simulate IBIS-AMI. Are you able to try the IBIS-AMI example project in order to confirm that everything in the model is present and working?
Drew
Yes, I want to use IBIS-AMI at HyperLynx tool. it just shows error message. I do not have ADS tool to try.
Apologies for the delay. Using a dll dependencies viewer, it appears the following dll in C:\Windows\system32 are dependencies for the IBIS-AMI model. Can you confirm that these are present in your system?
Drew
It has kernl32.dll. But I cannot find msvcr100.dll and msvcp100.dll.
Where can I load those 2 files?
cannie
Hi Cannie,
It looks like these are a part of Microsoft Visual C++. Please try installing Microsoft Visual C++.
https://www.microsoft.com/en-us/download/details.aspx?id=26999
Drew
