Part Number: TUSB522P
Hi Expert,
I found the layout guidelines in the datasheet. what is the different as below two request?
Each pair should be separated at least by 3 times the signal trace width.
In order to minimize crosstalk, TI recommends keeping high-speed signals away from each other. Each pair must be separated by at least 5 times the signal trace width. Separating with ground also helps minimize crosstalk.
