Part Number: DS90UB941AS-Q1
I have l questions to interrupt you about DS90UB941AS, about the DSI_CONFIG_0 registers bit4, if DSI_SYNC_PULSES=1, it means regenerate original VS/HS timing.
I don't understand how to regenerate the original VS/HS timing. or how to know the original HS/VS width?
Another question about DS90UB941AS, if BRIDGE_CLK_MODE = 0, DSI Reference Clock Mode. If the input DSI clock disappeared suddenly, does the FPD link disconnect?
if the low frequency control signal could transmission normally?
Best regards
kailyn
