Other Parts Discussed in Thread: TLIN1431EVM,
In pin mode, HSS pin is controlled by HSSC pin. the datasheet does not specify HSSC = High or Low to turn on HSS pin output. does the below description indicates that HSSC = LOW will turn on HSS pin output and the default configuration is HSS output on since there is a 350k pulldown on HSSC pin.
