Part Number: TUSB522P
Hi Expert,
If the TUSB522P TX and RX can be reversed? Can the pre-channel/ post-channel use 85 impendence?
Hi Far,
That is correct, both the pre and post channel of the TUSB522P can use an 85Ω differential impedance.
However, I am unsure what you mean by reversing TX and RX. You cannot swap the TX outputs with the RX inputs, however you can swap which side of the device will connect to the USB host or Receptacle.
Shane
