Part Number: TUSB1002A
お世話になっております。
CS1856198で提供いただいたComponent Data Sheetについて確認がございます。
・型格:TUSB1002AIRGER
・物品番号:CA46740-3413
<確認事項>
TUSB1002AIRGER _371MAC_ComponentDataSheet(forVendor)J-ver4.30.xlsmにある
Auめっき厚みの最大値と部品高さの公差を教えて下さい。
お世話になっております。
・型格:TUSB1002AIRGER
・物品番号:CA46740-3413
<確認事項>
Are you asking for the TUSB1002A package maximum plating thickness and part height tolerance? If this is the case, then please give me few days and let me see if I can find this information.
David
Thank you for your reply
Yes, Please provide information on the maximum plating thickness and part height tolerance for the TUSB1002A package.
When will you be done this?
HI,
We spec VQFNs like RGE at 1 mm max. Typically the tolerance specified on package drawings across industry is +/- 0.1 mm.
David
Thank you for your answer about the part height tolerance of the TUSB1002A package.
Please reply information on the maximum plating thickness.
For both top and bottom, the plating thickness for rough PPF will be 0.003~0.009um.
David
I appreciate your quick response.
"TUSB1002AIRGER _371MAC_ComponentDataSheet(forVendor)J-ver4.30.xlsm" states that the minimum electrode gap is 0.5mm, but we have been informed that it is incorrect.
What is the minimum conductor gap between the heat slug and the electrode ?
Can you please share the file so I can double check with our package team?
David
I'm sorry for the late reply to your inquiry.
Please find attached file.TUSB1002AIRGER _371MAC_ComponentDataSheet(forVendor)J-ver4.30.xlsm
Please give me few days and let me check with our package team. I will provide a response as soon as I have the answer.
David
Please provide information on the minimum conductor gap shown in red in the attached diagram.
Please follow the stencil design recommendation in the TUSB1002A datasheet.
Please also refer to this app note for more detail on the package landing pattern design, https://www.ti.com/lit/an/slua271b/slua271b.pdf.
David
I checked the datasheet, but I can't find the value for the minimum conductor gap in the figure.
Please let me know the size in the red part.
Please download TUSB1002A CAD using this link, webench.ti.com/.../cad.cgi you will find the value for the gap.
David
