Part Number: DP83TD510E-EVM
Other Parts Discussed in Thread: DP83822I
I am currently trying to construct a media converter using the 510E SPE-PHY.
In different products we use a non-TI regular PHY (LAN8720A) that I would like to continue using for the media converter together with the 510E.
I connected both PHYs through RMII, I bascially used the Eval Board and connected the other PHY instead of the DP83822I.
When using the standard SPE-PHY configuration I get no link. However when using different non-TI SPE-PHYs I can use the LAN8720A to build a media converter.
I already searched through all the strapping options, I made sure the Eval Board runs out of the box, which it did just fine and I checked all the RMII connections aswell as the clock.
Is there any restrictions on using the 510E with different PHYs in media conversion mode or am I missing some register inputs?
Thanks a lot for your suggestions.
Greetings,
Jan
