Part Number: DP83825EVM
Other Parts Discussed in Thread: TMS320F28388D
when can I expect the release update of the User's Guide. The one on the web is fitting to the old release.
Regards, Holger
Regards, Holger
please confirm,
Customer die below changes (sl. no. 1 &2 ) while connecting DP83825 EVM to customer board:
1) Remove: R9, R10, R17, R53, R54,
2) Populate: R11, R12, R13, R14, R15, R16, R18
3) Solder clock to J12 (output to MAC) - checked CLK_OUT signal at R30, it’s 50MHZ.
Is connection CLK_OUT signal to MAC needed?
ENET_RMII_CLK (25MHz) connection to R41 of DP83825 EVM to GPIO 73 of TMS320F28388D evm.
Regards, Holger
Hi Holger,
Hillman Lin
Hi Lin,
I got the info from the following e2e thread:
I thought a loopback may be a good first test.
Customer still can't write to BMCR register. Could the CLK be the problem?
Regards, Holger
Hi Holger,
I think MDIO/MDC would be the issue if you are not able to write a register. Did you have a 2.2kohms pull up resistor on the MDIO line? Could you also probe the signal of MDIO and MDC lines?
Hillman Lin
