Part Number: DS90UB941AS-Q1
Hi team,
Can P and N be used interchangeably on DS90UB941AS-Q1 Port0 Output?
We found that swapping P and N works just as well.
Xiaoxiang
Hi team,
Xiaoxiang
Hi Xiaxiang,
No, this device does not support this feature.
Gil Abarca
Hi Gil,
We found an interesting phenomenon on the customer side.
The customer's DOUT+ and DOUT- are connected in reverse, and the result can work normally, but DOUT+ and DOUT- are connected according to the correct cable sequence, but it doesn't work.
So we want to confirm, if it is not a hardware connection problem, is it possible that the DSI signal output by the SOC is wrong?
Is there a way to adjust the DSI signals output by the SOC into the correct order?
Xiaoxiang
Hi Xiaxiang,
Can you clarify what you mean by correct cable sequence?
Please share additional information:
1. Can you share the schematic?
Gil Abarca
