Part Number: TCA9537
Other Parts Discussed in Thread: STRIKE
when we apply an ESD-pulse sequence to our chassis (air discharge 15kV), the TCA9537 will sometimes go to a state where the I2C is not responding and the device can not be initialized. However, the device is still correctly setting the interrupt pin INT when one of the Px pins is toggled. Pulling the RESET line low does not help in this cases- afterwards, the device I2C is still locked. Only toggling the supply voltage of the device will make the TCA communication work again.
Under "normal" conditions our reset pulse is working fine, it just happens on repeated ESD discharge.
Is this a known issue?
Karina
