Part Number: DS90UB936-Q1
Other Parts Discussed in Thread: DS90UB935-Q1
Hi Team,
Could you please kindly help to check below questions comes from customer:
From 953 design application note, we did know that with lower forward channel data rate, customer need to use capacitor which larger than 33nf/15nf, and from DS90UB936 datasheet, we can know that the AC couple capacitor also related with back channel data rate.
#1 For customer design, they use REFCLK=25MHZ for DS90UB936, under this kind of situation, if the FPD-Link line rate=160*25=4Gbps is fixed? Could customer change the FPD-Link line rate to 2Gbps?
#2 For DS90UB935+DS90UB936, if the FPD-Link line rate rate=2Gbps, Back channel rate=25Mbps, then, what kind of AC couple capacitor we recommend? And how about forward channel rate=2Gbps and back channel rate=10Mbps? Do we have matrix table which could show the forward channel rate/back channel rate/Recommend AC couple capacitor?
#3 If customer change back channel rate from 50Mbps to 25Mbps by software for DS90UB936, then, if customer POC circuit need to change? Any risk here?
Thanks a lot for your support to confirm.
Best regards
Jie
