Part Number: TUSB4041I
We have the same problem with this chip: the Port 1 is broken on minimum 5 pcs.!
I have connected by wire the external connector to the unused Port 3 and it works and we could not damage Port 3 by hot-swapping the hardware.
Texas don't you think that the Port 1 is not identical to the other 3 ports inside the chip and too sensitive for ESD? As I just wired the external connector from Port 1 to Port 3 and the same parts exists in the line from IC pin to connector pin.
This thread belongs to this closed one: e2e.ti.com/.../tusb4041i-tusb4041i-downstream-port-failure-issue
