Part Number: DP83822I
Customer found the LINK is abnormal with DP83822I.
Here diagram is likely customer system architecture.
Problem description:
In OUT1 EtherCAT channel, the DP83822/DP83849/KSZ8051/KSZ8081/LAN9252 are Link pass.
In OUT2 EtherCAT channel, the DP83822 is link fail, other PHY as DP83849/KSZ8051/KSZ8081/LAN9252 are Link pass.
There 3 PHYs of VSC8541(x3pcs) in Main EtherCAT Module.
Pls find the register values with DP83822 LINK fail.
Out 2 Reg (83822, LINK Fail)
Read_PHY0_Data[18] uint16_t 0xe600 (Hex) // False Carrier Counter Half-Full Interrupt: 1 = False Carrier HF interrupt is pending
Read_PHY0_Data[23] uint16_t 0x4d (Hex) //RX FIFO Underflow Status: 1 = Underflow detected
Brian
