Part Number: SN65DP159
Other Parts Discussed in Thread: TDP142
Does this part support Displayport 1.2A or better? If not what is the highest version it will support?
DP159 output is not DP compliant. Is the source DP compliant? If the source is DP compliant, then you can use SN65DP141, https://www.ti.com/lit/ds/symlink/sn65dp141.pdf or TDP142, https://www.ti.com/lit/ds/symlink/tdp142.pdf linear re-driver. If the source is not DP compliant, then you can use SN75D{130, https://www.ti.com/lit/ds/symlink/sn75dp130.pdf.
David
